Item:
ACL Bearings
ACL RACE SERIES Crankshaft Main Bearing Set Standard Size (7M2428H-STD)
ACL RACE SERIES Connecting Rod Bearing Set Standard Size (6B2960H)
Condition:
BRAND NEW - Still in Sealed wrap
Price:
$250 + Postage and Handling
DROP to
$200 + Postage and Handling
Pics:
Thanks
Edited by Owgasm
  • 3 weeks later...
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
