hi, i recently replaced my walbro (255 LPH) fuel pump with the same walbro fuel pump (255 LPH) in my r33 (rb25det) and my car is running a little ruff, at idle it would bounce from 800 rpm to 1100, when starting sometimes it would stall or nearly stall, and of a morning (when it is cold) it will idle anywhere between 1500 rpm - 2000 rpm!... replacing the same fuel pump shouldnt change a thing so i thought. and yes the part no. is the same (GSS342).
what could it be? any suggestions or info will be great.
cheers 4drftn
try changing the fuel filter, its in the engine bay near the plenum and costs about 30-40 bucks from nissan.
If thats not it, unfortunately you will have to open the fuel tank and have a squiz. similar thing happened to me, where the bosch 040 was installed with a hose that got eaten by the petrol and so the pressure was not getting through 100%. (despite the repco guy telling me it was submersible efi hose- bastard)
what ecu is that on? if not stock perhaps the low rev light load maps need looking at
yeah i replaced my fuel filter going back about 2 months ago... would the fuel get eaten away that quick? i know the piece of hose between the pump and the bottom part of the bracket might not as it was a bit of left over hose from when i changed my fuel filter... might have to look at that... not looking forwards to taking it back out though
my ecu is a microtech LT-8 which controls my fuel and ignition so could be it... sadly i dont have a hand set, but i should be able to take it to a performance place to get it checked out.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
