VinYls...
Taren - But hes in NSW
Metal Ink - NSW
Rated R Designs - NSW
Do you want a full design, or just a couple of logos? Cause they can be made and sent pretty easily... Full design is a bit different...
i emailed metal ink no reply..
and yer a full design... does Taren and Rarted R designs have a web site or email?
https://www.sau.com.au/forums/topic/183914-vinals/#findComment-3330615
both do, i hope i can remember them...
http://www.ratedrdesigns.com.au/
http://www.apexgfx.com/
But someone you can talk to face to face would be better for a full design... You might want to find someone in the same state as you...
I know the guy that owns that car :blink:
https://www.sau.com.au/forums/topic/183914-vinals/#findComment-3330620
cheers mate much appreciated! will at least get a quote!
thanks
https://www.sau.com.au/forums/topic/183914-vinals/#findComment-3330639
  • 4 weeks later...
VinYls...
Taran did mine for my old R33, i just needed some vinyls for autosalon, only reason y i got them...
Im in melbourne and his in NSW but he sent them down to me via post
His cheap too, you will find not many people can really beat him
www.apexgfx.com
Heres my old car which he did...
his got some of his work on his webpage too
-Ferah :rolleyes:
Edited by DNGRUS
https://www.sau.com.au/forums/topic/183914-vinals/#findComment-3384291
adz- theres a guy on here actually.. He has his own business set up
He owns a silver s2, with black stockies..
Maybe check my threads (silver s2 pics), to check for his username..
edit: he has put one on his 33.. Looks awesome
When i go home, i will hunt for a pic.. hahahah i always have pics for you!! hehehehehhe
Edited by siddr20
https://www.sau.com.au/forums/topic/183914-vinals/#findComment-3385152
No they don't ruin the paint at all...RatedRdesigns did an excellent job on my old R34 but he doesn't do vinyls anymore..
http://www.autospeed.com/cms/A_2142/article.html
Metal-ink work look awesome too.
And don't try to put them on yourself if you've never done it before .. I tried it and ruined the whole sticker. Really hard
https://www.sau.com.au/forums/topic/183914-vinals/#findComment-3402269
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
