i have a gtr33 v spec with a power fc and need to check the timming , the problem i have is ,when i used the timing light i cant pick up 20 degrees on the pulley i keep fluctuating .going and comming all over the place . what could be the problem
https://www.sau.com.au/forums/topic/184154-cas/
I HAVE JUST CHECK MY TIMMING AND COULD NOT GET IT TO 20 DEGREES BECAUSE THE TIMMING KEPT JUMPING ALL OVER AND NOT STEADING OUT . ALSO THE ENGINE STALL WHILE CHECKING TIMMING AND THE TIMMING LIGHT STILL WORKING . WHAT CAUSES THE LIGHT TO WORK WHEN THE ENGINE IS DEAD.
https://www.sau.com.au/forums/topic/184154-cas/#findComment-3337273
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
