why are u guys goin to all this trouble to get the dayz ones made up from scratch when there is already places making other (better in my opinion) kits ready to go, front, side and rear.. just my thought neway..
Oooh, if they were made from flexible composite like some of the drift kits.... like the ones supplied by Flex-Fiber Duraflex or M-FleX, that would be extremely nice... In this case however I don't think the kit parts will be flex composite... not sure the process you'd need for what I'm guessing is a urethane/fiberglass composite item, but I'm guessing for a small number run like this it'd be far too expensive. Although it'd be cheaper than pure urethane parts, and stronger too.
i can't belive what iam reading. other places making BETTER i want to see it. i HAVE NOT EVER seen a fiberglass shop produce a bettter body kit than what andrew at customcarbon can. the man is a guru and knows his shit about all fibre glass and carbon componets. not to mention the quality of products he uses only the best. as for will they be strong enough they are still glass however you will get a better stronger product from c3 (customcarbon) . if any of you doubt this go and see andrew he is a great bloke who will be more than happy to have a chat and tell you all about the glassing/carbon work he does and can do. if i needed a kit i whould be there. (i am getting my nismo copy side skirts there better than my shit ones that don't fit proply.) but i all ready have a days rear and have a 260rs front so unfortnatly i don't need a dayz kit. mike is right about the number plate holder get rid of it looks sweet with out it. :( thats just my 2cents i had to leave.
died a cruel death my friends like most group buys uless you can talk yunis into swapping bars with me lol nudge nudge wink wink say no more :(
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
