hi everyone, i just fitted a fmic to my r33 and im having alot of trouble with boost spike over 5000rpm. An exact description, ok i put my foot down in any gear :O and the needle (i know this is a bad way to read your boost level) goes straight to the middle bar between 0 and 7mmhg or whatever (:D) then at about 4800rpm it suddenly spikes to JUST under the 7, as soon as it does it i jump straight off the throttle as im not keen on blowing stuff up, ive fiddled and farted around with vacuum lines hoping it may just be a simple thing but havent had any luck. Right now its running straight off the actuator to the line in that usually goes to the bov and ive blocked off the carbon cannister and used that line for the bov. has anyone had trouble like this?HEEELP :)
p.s engine mods are:
3in turbo back exh with high flow cat
hard pipe intake thingy
walbro fp and new coilpacks (and fmic now). i am about to fit an avcr and safc but i want to sort this problem out first :)
https://www.sau.com.au/forums/topic/185775-boost-control-problems-stock-boost/
yeh weld a nipple onto the cooler pipe, or you can get threaded ones to screw in. I had the same problem when I installed mine a yr ago. It should be sweet once you get the nipple put onto the cooler pipe. Put it in same location as stock one and run to the actuator. Perhaps till you do this, unpug the stock boost solenoid and it may not go as high. :thumbsup:
HI toffy, come and see my setup, same issue, i drilled and tapped the cast pipe to the TP ilet and plumed it off that, go an see scott at the purple pig and ask for a nipple connection, he has a few, i have some actually come to think of it.
hi everyone, i just fitted a fmic to my r33 and im having alot of trouble with boost spike over 5000rpm. An exact description, ok i put my foot down in any gear :) and the needle (i know this is a bad way to read your boost level) goes straight to the middle bar between 0 and 7mmhg or whatever ( :( ) then at about 4800rpm it suddenly spikes to JUST under the 7, as soon as it does it i jump straight off the throttle as im not keen on blowing stuff up, ive fiddled and farted around with vacuum lines hoping it may just be a simple thing but havent had any luck. Right now its running straight off the actuator to the line in that usually goes to the bov and ive blocked off the carbon cannister and used that line for the bov. has anyone had trouble like this?HEEELP :P
walbro fp and new coilpacks (and fmic now). i am about to fit an avcr and safc but i want to sort this problem out first :P
hey mate
firstly what kind of boost controler you using
two save your money and dont get a safc and get a pfc..............
the pfc will fix that prob easier
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
    • Wow. Pissy much? You on a mission to find old posts to argue with, or is this legitimately just because you're 5 years into a 1 day job?
