I've decided it's time for a change so I'm selling my old Rays rims.
They are 18 x 9.5's (+12) Rays Nismo LMGT4's all round and come with High Performance Advan Neova AD07 tyres (70%).
I also have a replacement set of Nismo stickers for them as some of the old ones are gone (I once tried using a special wheel cleaning spray and all the stickers came off).
The rims are in good condition except for a small gutter rash on one rim (which with the bronze rims you don't notice unless you are looking really closely).
I'll put pics up of the rims individually over the weekend.
The rims are in Melbourne and I'd prefer pick-up.
Price: $2,500.00 firm.
I can be contacted via PM or on 0419 375 140.
https://www.sau.com.au/forums/topic/186005-18x95-lmgt4-rims-bronze/
Yeah its slightly too wide, im running 18x9.5 +12 te37s on my car now and you either run negative camber at the front or undersized tyres. The back is fine.
Always preferred lmgt4's to te37's tho :thumbsup:
  • 3 months later...
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
