Hey guys, anyone know a good place to buy outright mobile phone? Dont recommend ebay as if those phones are not australian models then the companies wont give warrantee. Internet shops or any places around Melb West would be great.
https://www.sau.com.au/forums/topic/186016-mobile-phone-store/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
