the studs and nuts that hold the turbo's on are good to change. once they've been on for a while and you loosen them of they just don't have the same holding torque anymore. don't really want them rattling loose. lines would all depend on the quality of the existing lines and also the demand that the new turbos require. would want to starve them of oil and, if needed, water.
its for the styling if you replace them with braided. what kinda turbo's are you planning on running. Replace the bolts, and don't forget a good new gasket set from nissan, these are highly recommended.
I replace as much as I can, so when I need to play with it again, i don't have to go through working with rusted or stretched bolts and rounded nuts.
- All gaskets should be OEM Nissan where possible
- New manifold studs, and nuts (lube when torqueing to prevent over tightening, and use (I fabricate) metal tabs to bend over the nut to prevent loosening.
- I too recommend investing some coin on race fittings and braid. Don’t be tempted with knock off Korean stuff, stick to Speedflow, Earls etc. Swivel fittings will help with setting up the pipe runs.
- Don’t forget shield from heat, and abrasion. Small gauge braided line will cut through anything if left to rub on it long enough.
- Unfortunately many people use race fittings simply cus they look shite hot, but I reckon they should be used to speeden up and secure, the disconnect / connecting of lines. They'll minimize leaks and of course last longer. Keep in mind these attributes and use them to improve Nissan's original design (my modifying mantra :P
- Notice the way Nissan design the water feed for the turbos for instance. Its taken from the interior heater hose (A) (back of motor, drivers side firewall) comes round passenger side, round front of motor and empties on nipple near thermostat (B) In between those two points, waters "T'd" off for the turbos. Clearly this was designed so that water flowing through the lines that run close to the manifold doesn’t get heated up while waiting to go through the turbo; there’s a continued loop of coolant, always providing the cartridges at "close to" engine temp.
- You'll notice the pain and hassle of removing perished rubber hoses, dodgey wire and compression clamps off; replace hoses and fit good quality worm driven clamps, and "T-bolt" clamps for larger bore pipes. (If I cant find a worm drive clamp im familiar with, I buy one, take it home and torque it till it skips a tooth... all aren't made equal) Out of habit, I double clamp critical pressure / vacuum hoses
- Good time to degrease blowby oil from all piping (Degreaser soak then meth / Kero mix)
Hope it helps
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
