Hey didnt know where to post this so if its wrong section feel free to move...i got epa last nite for havin air filter+ intercooler so im puttin standard airbox back in, standard exhaust um i have boost controller greddy profec B, now he didnt say nethin about where it was mounted more the solenoid under the hood rekons its illegal is this true will i have 2 re-connect up 2 my standard boost solenoid?
also everythin else is standard no Ecu so im safe there nethin else epa picks on other than ECU, EXHAUST, AIR FILTER + Pod ?
https://www.sau.com.au/forums/topic/187892-epa/
The look for mostly:
pod/cooler (only one mod to intake allowed)
cat convertor (you need one)
boost controller (variable boost is not allowed)
blow off valve (must be a plumb back)
exhaust (must be under 90db)
aftermarket ecu (no modification to ecu is allowed)
aftermarket turbo (not allowed)
Thats the main stuff, but check the thread below for more info.
http://www.skylinesaustralia.com/forums/t156269.html
Edited by stolen_s15
https://www.sau.com.au/forums/topic/187892-epa/#findComment-3389641
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
