Hey Guys,
This car would suit some one who wants a dedicated drift car! Had it on the dyno about a month ago made 264.5 kw at the tread
It rev's to 9000rpm.... very serious car.... the car was built in japan with computer this car could easily make 300kw with the gear that is on there
The car can be complied and registered
need to sell the car will consider trades
call me on 0412 209 069 or pm me
looking for $16,500ono
will strip the car but only if the engine sell first
cheers
NiCk A
ps im located se melbourne
1992 180sx
Tomei 2.2ltr motor :)
Trust TD06-25g Turbo kit (externally gated trust manifold screamer pipe)
Trust Intake plenum
trust manual boost controller
trust revic controller
tuned ecu
17" Volk rims
Twin Plate Clutch
2 way lsd
Bosch 044 external fuel pump
r33 gtr fuel pump(lift to the surge)
External Surge Tank
Roll cage
Bride Brix seat
lots of gauges
Full exhaust system
JIC suspension
the list goes on and on
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
