OK guys & girls im looking/thinking about selling my pride & joy to upgrade to GTR but will only sell at the price i want! No offers!
STRICTLY EOI AT THE MOMENT!
1996 Series 2 GTST with dual air bags, Rare Active Lsd Model, now with mechanical diff
$18,500 rego expires on Nov 2 07
127,000kms serviced regularly 3,000-5,000kms
Plates WPN-033
EXTERIOR
R32 GTR Rims with new rubber on the Front, will supply standard rims painted black
Stealth/Drift wing
Nismo 400r Style Side skirts
Fibre glass lip on standard bar - in bad condition.
Reverse Sensor... comes in handy
Clear Nismo Indicators
INTERIOR
TRUST gear knob
Knock link
Blitz Dual - SBC boost controler
Clarion CD player
Central locking
3 point immobiliser
Window tinting
Greddy Twin A-Pillar with 1 x Air fuel ratio & 1 x Boost gauge
ENGINE
Hybrid front mount intercooler
Greddy catch can with earls firrings
Master cylinder brake brace
Sard 500hp fuel pump
Sard 650cc fuel inj. Std injectors will be provided
Sard fuel pressure reg.
Splitfire coils
Highflowed turbo by Precision Turbochargers
Brand new Braided Oil lines to the Turbo
LINK ecu
3 inch exhaust from turbo back
Blitz NUR Spec muffler
Exedy heavy duty single plate clutch
K&N airpod with cold air induction through the front bar
HANDLING
Tein HR height adjustable coilovers - Also will supply original suspension
GTR rear sway bar
Tomei electronic Hicas lock kit
Brand new Brake Pads Bendix Ultimate on the front
Bendix pads on rear
Mechanical diff. pretty sure its a 2-way
Adjustable rear camber arms
Serviced just this week 15/03/08
I had the car dyno tuned recently at Croydon CRD, Also fitted a new CAS- Crank Angle Sensor & new 5'' Stainlees Cat Converter.. 3/8/07
Power is 232rwkw on 17-18psi
Most mods were perfomed by Advan Performance & Had engine Drive belts replaced earlier at SAS .
All dyno sheets & receipts will be provided
PM If you are interested in this car.
https://www.sau.com.au/forums/topic/188182-r33-gtst-s2-silver-with-mods/
I see this car everyday. It is tough yet subtle, goes bloody hard and sounds horny as.
I'll put it this way, if you are in the market for an R33 Series II you need to have a look at this car. I seriously doubt you'll be able to resist paying the asking price once you experience this package.
:D
might you be interested in swaping for a GTR?
http://www.skylinesaustralia.com/forums/t187303.html
PM SENT.
Hey thanks Drew, i will miss it if it goes...
Hey phill, thanks for the kind words, & yeh i know lea has a nice car to swap but hmmmmmmmmm its not nice for me :dry:
Hey bill..
Can really give the thumbs up to this car..True and honest example of a series 2..the hard works been done and the mods are there to back up all the work..(DONT SELL IT BILLY)you might not miss it but i will..haha
Owner will defanatly not look back.. geniune car guys..
  • 1 month later...
  • 3 months later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
  • 4 years later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
