hey guys, ive got a fmic laying around and wants to get rid of SOLD SOLD SOLD
Purchase beginning of the year, has been fitted on my 34, and has been replaced last month due to upgrade
condition: a few bented fins on one side, otherwise works perfectly.
pictures attatch
price $160
