  • Replies 73
Too right, I use THIS SITE to find mine. But you can just google "Nintendo DS roms" or something and any site will do.
Bought one of these r4ds's as gift for someone for Christmas. Just wondering if I load it full of games from this site will the games be in English?
No region issues with the ds. the only thing is, chinese roms can only be played on chinese ds units, that's more a limitation of the hardware in ds's sold outside china not being able to cope with characters. Its for this reason you don't see many chinese nds roms on english websites, yet plenty of japanese/eur/usa roms.
awesome links guys, order will be placed tonight.
xmas pressie delimer solved.
they should sticky this thread here ;)
howie i was wondering wtf you were talking about at scs. it all makes sense now
Edited by gzilla
quick noob question, are these sd cards it uses like the really small 1s that go in your phone or like the style that come out of camera's.
i dont know jack about em just been told their different.
MicroSD are used in alot of appliances, like phones and cameras. But they vary between brands, for example R4DS has incompatibilities with some non-kingston branded chips.
I don't think it's illegal to back up your software and playing home brews on your R4DS card. The sony mod-chip case proved that.
Additional, i don't condone piracy, i believe software vendors are struggling, that's why i always purchase a game if I really enjoy it. Same with DVD's and CD's. But there's a distinction between piracy and having something in the public domain where anyone can have access to software, chances are the games and software that these have been built upon are based on tools us software developers have written and given for free on the internet - they can make money from our inventions, but they really can't stop you from trialling their software.
well i think its a lot more convienient carrying 1 game catridge with all your games you have paid for the ds on it, than a bag full of 20 of the lil bugga's.
plus that way you can keep the originals minto :) dont think it can top my minto cd's collection :( ive got crazy old cd's that look like they just came out the shop cause i only use copy's in my car, which saved me a crapload when my last car got broken into and they took em all :D u only got cheap copy's sucka's
Edited by gzilla
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
