For Sale
Nissan Skyline R33 GTS-T 1994 Model
Colour: Deep Lilac Purple
Odo: 118,000 kms
Engine/Performance Mods:
- HKS Pod Filter + Z32 Airflow Mtr.
- Blitz BOV
- Hybrid FMIC
- 5Zigen 3" Turbo Back exhaust
- Bosche 040 Fuel Pump
- Apexi AVC-R Boost Controller
- Apexi Power FC and Hand Controller
- Apexi Boost Gauge
- GReddy Turbo Timer
- R34 Strut Brace
- Exceedy Heavy Duty Clutch
Cosmetic Mods:
- GTR Sideskirts and rear bar and pods
- JUN Rear wing
- TRUST Front Bar
- Lenso 19" White Twin 5 Spoke Wheels and Falken Tyres
- MOMO Commando Steering Wheel
- Viper Alarm System
- Chrome Billet Handbrake + Gearstick
- Racing Pedals
- White Dash Dials and Illumination (Blue)
- Alpine CD Head Unit
- Rockford Fosgate 6" (Front) Sony Competition Xplod 6" (Rear)
- Sony 12" 1300W Subwoofer
Very reliable car and have had no problems with it. Progressed with mods slowly over the past few years. As I see it, this car is ready to make big power. I have completed everything so far and left the major work for last. If not this car makes a safe 200rwkw on 12psi on low boost if it will be a daily driver (high boost 14spi). Great JDM look that turns heads, very reluctant sale. Many hours of blood, sweat and tears put into this car.
$16,500 negotiable
Contact: Justin
Email: [email protected]
Any offers considered. Welcome to take a look at the car anytime just PM me.
Edited by kGB
https://www.sau.com.au/forums/topic/189675-nissan-skyline-r33-gts-t-1994-model/
Price drop $18,000 LOL Ive heard selling R33's is about as painful as doing a rebuild in a 300ZX. HA!
300ZX rebuilds are easier.
your car looks decent.
under $15K It would sell... but I'd say you will be waiting for a while at that price.
People will always come back at you with "series 2's are now under $15K"
which they are..
You just gotta find the right person for your car..
Hopefully you will.
Maybe start a hobby while you wait.. like vg30dett rebuilding.
*No bump intended* I really don't get this huge Series 1/Series 2 rivalry. But anyhow this is just a feel for the market and what people are paying for things. In all honesty I want to buy a GTR. Not sure the series but an R32 sounds good. A GTS is a GTS still even after any engine conversion or turbo upgrade...
Edited by kGB
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
