hey i have a toshiba A200/G01 laptop!
BRAND NEW!! box has been opened to check it and put back!
RRP on these are still selling for $1999.99
FEATURES SPECIFICATIONS
CPU TYPE Intel Core 2 Duo Processor 64-Bit, L 2mb Cache
MEMORY (STANDARD/MAX) 2GB (1GB+1GB) DDR2 667MHz
VIDEO CARD TYPE ATI Mobility Radeon 256MB Dedicated graphics, Maximum Graphics with HeyperMemory is 1023MB
OPTICAL DRIVE Built-In Super Multi Double layer Drive (DVD+R DLx2.4, DVD-RAMx3, DVD±Rx8, DVD±RWx4)
DISPLAY SIZE/RESOLUTION Stunning 15.4" TruBrite™ Clear Super View widescreen (XGA+) 1280 x 800
SOUND/SPEAKERS Premium Harmon Kardon Speakers
VOLUME CONTROL, HEADPHONE, MICROPHONE Volume Control Dial, Headphone port, external microphone port, integrated microphone,
MODEM International 56k V92 Data/Fax modem
NETWORKING LAN 10/100 Base TX, Wireless LAN 802.11 a/g/n
TYPE OF PORTS 1x Express Card slot, 4 x Hi-Speed USB 2.0, 1 SVGA, 1 Firewire, 1 HDMI, 1 TV-Out (S-Video) 5 in 1 Card Reader, Bluetooth 2.0
PORT REPLICATOR FACILITY Cybershop Recommends Belkin Express Dock
BATTERY TYPE/USAGE Approx up to 3 hours* (6 cell) usage maximum
OPERATING SYSTEM Microsoft Windows Vista Home Premium (No Recovery Disc)
ADDITIONAL SOFTWARE Toshiba user’s manual, Toshiba value added package, Norton Internet Security™ 2007 (90day trial), Ulead® DVD MovieWriter® for Toshiba. No Windows Recovery Disc included - make your own
ADDITIONAL FEATURES FingerPrint Biometric Reader, Card reader - XD, Memory Stick, SD , Remote Control
DIMENSIONS & WEIGHT 360 x 267 x 29.8(front)/36.8(rear) mm, 2.7KG
WARRANTY 1 Year Parts and Labour International Warranty with FREE Courier Pickup in Australia*
looking for $1600!
as i said BRAND NEW!!!
FREE postage..
contact me via pm or quicker by phone or email
[email protected] or 0433290801
cheers adrian
https://www.sau.com.au/forums/topic/191613-toshiba-laptop/
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
