Hey all,
Sorry if this is in the wrong spot.
Just want to know if anyone knows if crow cam's are any good (or bad)
I was going to get some for my SR20det.
But if anyone has some either in their skyline or other import, i am keen to hear of their experiences.
Cheers, Warwick.
https://www.sau.com.au/forums/topic/191664-crow-cams-any-good/
Where I used to work, we sold a huge amount of crow gear, and I never heard a bad word about their product. If you're happy with the grind and lift that the cams offer you, then there's absolutely no reason not not to use them. At the end of the day, it's 'just' a camshaft, and a tomei cam next to a crow cam with the same grind, will do the same job, and very likely a fair bit cheaper. Be careful of getting caught up in brand-naming :) The hot jap cars use the hot jap brands, but they're a whole lot cheaper over there...if there's a quality local product cheaper than the jap product, it's the way to go ;) Unless you want the sticker for your door...
RM.
Hey all,
Cheers, Warwick.
line up the crow cam sticker with the holley/B&M/Rocket/Pissing on ford ones and she'll be apples!
but in all seriousness if they were a bunch cheaper why not? if there were the same price i would probably get the tomei (but ima sticker queen)
Not in imports, so far i have had very little sucess... the tolerances (base circles etc) have been way out even after trying 2 freshly ground sets... dropped in a set of hks with no dramas... for V8 no dramas but for the latter model stuff not a chance in hell i will ever use them again.
Warwick i am happy to explain just how bad they are in SR's via pm.
I can't even see anything on their website anyway.
BUT Tighe cams appear to be good. :D
yeah Ivans cams seem to be good but i have only ever used them in V8's.... so i cant comment in SR
his cam my specs made my old broom go 12.2 with a 253 back in '99 in full street trim :) (haha 12.2 was quick back then.... bit slow nowadays)
save yourself the hassle and stick with a set of jap cams. tomei, hks etc that have specs to meet your requirements.
i'm not going to go into details about local companies, but for said engine, i'm just telling you so you can avoid potential headaches. is the local stuff any cheaper anyway?
the guys at nissansilvia would have direct experiences with cams for SR series engines, maybe pay them a visit, they aren't all knobs, some are ok...
URAS,
A mate of mine has a set of GTR reground cams from Ivan. Inlet 254 8.5mm lift 112 centreline; Exh. 254 8.5mm lift 117 centreline.
Picked up 26rwkw on 1psi less with the std centrelines. inlet was 112 and exhaust 117.
Didn't loose any down low, started to pick up power from mid range onwards and all though probably tune related its picked up fuel economy.
From memory the cams were $220 for the pair to regrind. He said he can also offer the 265's 8.9mm lift but I'm a tinny bit concerned about reducing the base circle to obtain those numbers. Soon to give him a buzz and see what he thinks about my concerns.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
