Considering Moving Interstate for a job offer. Car needs to go because I'm getting serious about my future. Has never disappointed me.
Make: Nissan
Model: 1993 180sx
Colour: Metallic Red
Rego - October 2008
Insurance is covered by Just Cars. Never made a claim.
Transmission: 5 Spd Manual
Odometer: 170,xxx (clocked it to 000 today).
Bits: All electric options, space saver, original Jack(nissan jacks are horrid), globes and replaceables all taken care of.
Engine:
- SR20DET Red Top running t25G with no problems ever. All EGR gear there
- Both Gearbox Mount and Engine Mounts have been replaced.
- HKS Power Intake
- Hi Octane Air diversion Plate
- Sump has been bashed out to maximize capacity and painted black to look nice
- Gel Cell Battery with less then 5000kms *may be removed if needed*
- Full Turbo back exhaust system. Car only smokes white from perspiration in the winters. Haven't seen ANY sort of smoke in the two Springs I've had it (so turbo, water,oils seem to be good nick), let alone summer.
-X-Force Cat Converter put in 5000km ago. 02 Sensor changed at same time.
Handling:
- Front Whiteline Castor Bushes (less rattle then pillowball gear)
- Front Whiteline Camber Pins
- Rear Whiteline Camber Bushes
- Upper Whiteline Bushes (expensive labour...need to drop subframe to do them. Drives like a newer car!)
Interior:
- s15 Rear View Mirror
- 180sx Floor mats
-Alarm Installed by Brett from PCA. Very comprehensive install.
Exterior:
- Nismo Front Bar
- M- Sports Sideskirts
- Nissan Rear Pods
- H2 Globes (the ones down from the ricey globes on hondas), so may be H3, can confirm if needed, same as the stock H4 but useful.
- 16 inch Advan Tri Spokes powdercoated white wrapped in Pirelli P6000
- Comes with all centre caps -original
- Resprayed - Roof has been resprayed Black, against the body's Red.
- Centre Garnish Painted Black, but still leaving parkers visible.
- Non Smoking Car or anyone who does smoke hasn't gone near it (besides maybe the mechanic(can be proved because ciggie lighter doesn't work))
- Worn/aged Interior Parts have been replaced with OEM parts.
- As many worn rubber seals have been replaced as possible, however some are impossible to get (outside door seals, sunroof seals).
- Front Windscreen Seal has been replaced and still has lifetime warranty. Reason for this is because original seal was painted over by a previous spray job and looked horrid.
- Controller for Headunit mounted over ashtray (no one smokes in the car =P )
- Manual Controller for Amp disconnected
- Booklets/Manuals for SR20det in glovebox (specific manual for 180sx can be provided in softcopy)
Over $10,000 spent on this car. I've watched over as many jobs as I can and am well hated by alot of workshops for making them do things twice. Serviced more often than should have been. Most work done professionally at well known trusted workshops. One of the cleanest examples. Handles very very well, and runs and starts as well as a new car.
Looking for 11,500 o.n.o
Options:
Upgrade Options:
- Bilstein Shocks with new bumpstop and dustcovers ordered to match:
-Whiteline Springs
- Front and rear Whiteline Adjustable sway bars with extra notches (so equal to roadholder gear)
- Whiteline Pineapples
- Front Nissan Strut Brace
- Rear Cusco Adjustable Strut Brace
- Front RDA slotted rotors
Add - $1500
-Fet Turbo Timer
Add-$40
Sound
- Pioneer HeadUnit
- 6.5 Inch Component Splits (old school Phillips which replaced the Sony Xplods previously in the car)
- Jaycar Amplifier 4x100
- Running Boston Acoustic Cabling (or hertz...can't remember)
- Rockford Fosgate P1 12" Sub, Mounted in Sealed Box (Could be bigger box I guess)
- Running to Stinger Connections (cabling is probably worth more then these connections. However Autobarn was the only place open that night and this was the most expensive stuff they had)
- Running off a GelCell battery
-Add $500
Power FC
-Add $1000
**Car is selling for 11,500 ono without extra bits. Great condition stock car to mod your own way!!**
-Tri
Edited by trivial
  • 3 weeks later...
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
