Would you concider straight swap for a set of stock R34 rims? oh sorry might add fresh respray and repair on them (removed the stone chips and gutter marks.)
If yes pm me.. If not ill prob take your catch can cheers
Edited by DECIM8
https://www.sau.com.au/forums/topic/193739-sold/#findComment-3477020
hey man u live at the intersection of riley st? haha i think i go driftn out of ur street:P im da panda 33 n usually go for a nice drive with my mates bayside blue sil80 and my brother had a bayside blue sprinter.
back to business, which type of oil catch can from that link was it? round with breather/ square/ round with non breather/ D1 spec? ..either way sell the oil cooler to BWRGTR $350 and i'll pickup the catch can tonight. cheers
https://www.sau.com.au/forums/topic/193739-sold/#findComment-3480879
yeah thats me, second from the corner...yeah i know the cars...nice
mate its the top one on the page when you click the link.
I have an interstate buyer interested in just the oil cooler kit as well. first to deposit first to get.
when i sell the kit I will sell u the catch can.
Worlds longest bump...
https://www.sau.com.au/forums/topic/193739-sold/#findComment-3481324
  • 4 weeks later...
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
