$300 FOR ALL TOGETHER!!!!!!!!!!!!!!!!!!!!
OFFER ME FOR SEPERATE SELLING AS WELL!!!!
Item: Punch P4004 - 400 watt 4-channel amplifier
50x4 @ 4 ohms, 100x4 @ 2 ohms, 200x2 @ 4 ohms, 12dB/oct Butterworth HP/AP/LP crossover variable 40-400Hz, RCA inputs, RCA pass thrus, 2/4 ch switch, cast aluminum heatsink, military spec PCB, and remote cast aluminum heatsink, military spec PCB, and remote Punch Bass EQ with 0-18dB @ 45Hz. H 2.4" x W 11" x L 16.4"
Age: 2years
Condition: can't be better than this. they both subs and amp never loose their punching!!!
Price: Subs: one in the box - $100 firm
one without box - $80 firm (but if you wanna buy the box seperately and buy these two subs at onec ill give you at $150 for both!
AMP: not sure about the price.. i saw it sold as $400 at ebay about few months ago but i wont sell it as $400.. im thinking...would $250 will be ok...
Contact: 0431 715 991
Comments: i wont send interstate its too big for that and too much headache! tell me about your location and we meet up at the middle!
SMS me im at work..
cheers
paul
Edited by tyaos
ONLY SYDNEY PICK UP PLEASE!
they are so good system!
i paid $3000 at the first time i bought it!
i know all the sound system components price are getting
so low once they are second hand but these rockfords are
too good to be second hand!
please come and wipe them out and enjoy the best quality with only $300!!!!!!!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
