lol, I wish... what makes u say that?
no reason, was just a good opportunity to make a stupid joke :rofl:
i parked in the car park during autosalon earlier this year with no issues.
anyone know if SAU has a display on? (i'm guessing no, as no threads have been posted about it)
https://www.sau.com.au/forums/topic/195870-autosalon/#findComment-3507680
Um.. SAU does have a display on there. (main reason why I'm going)
and there IS a thread about it... biggest thread around, http://www.skylinesaustralia.com/forums/Au...on-t186034.html
lol..
I definitely won't be taking the 'line to the carpark..
https://www.sau.com.au/forums/topic/195870-autosalon/#findComment-3507689
