  • Replies 148
Yes you can plug an ethernet cord directly into the back of your xbox, if you want to do it wirelessly however you will need to purchase the wireless adapter.
Before you can play online you will need to purchase xbox live gold subscription which costs approx $90.
And yes it will drain your downlad limit. As a rough guide if you play everyday for a whole month you will use over 5gb
Another way for wireless without paying the $150+ for the adapter
watch this Youtube video and it shows how to hook to a pc or laptop and use the wireless on that
Click for Setup info
My laptop sits beside my xbox 360 so I do it this way.
There is also a few options for live starting from $10.95 for a month etc
you will need a credit card as it makes it easier.
I need halo 3 ppl to play with.. getting bored of playing with random ppl from america all the time..
Slimbo83 .. add me
I noticed you always play that. Everytime your i see your profile it says your playing halo. Do you have COD4 or Forza?
Sorry but im sooo over halo 3, so i wont be playing it anymore.
Trent & dnbutts, F/R's sent.
Edited by NRV155
Hey, yeh i've got COD4 but havent really played it much yet
if your always playing Halo 3 then why the hell do you still need my COD4.
gives it back boy!
gamertag is : dnbutts
very nice.
Bro, i sent you friend request but you havnt been online for days.
Also sent to R33line
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
