Hey guys,
in short dinner at halfway hotel then brewery christmas lights them cruise
dinner is booked for friday 14.12.07 7:30 at the halfway hotel pt road
come if you can bring your kids i am
me and bunny33 will be there and possibly her200sx
https://www.sau.com.au/forums/topic/197474-dinner-lights-and-cruise/
Was thinking of doing the same thing only yesterday . lol
Dont know about the pub part , but the light's and cruise sounds good.
This still depends wether or not my car is finished getting the front bar and bonnet resprayed. Its should be finished by tomorow afternoon if all goes to plan.
How big a cruise are you talking about ?
Car has only half a tank of fuel and would rather fill up on tuesday next week so next week would be better for me.
Next week instead of this week ?
Other wise will have to let you know then, Steve.
Edited by savage GTR
Yea no probs its not a proper sau dinner as i just thought yesterday i will take my daughter to see the lights so i rang bunny33 to see if she was keen and here we are
flick give us a ring when you finish we can let you know where we are
