Hey,
I have just recently done some mods and have the following R34 GTT parts available in fine working order and in good condition;
  • Standard Flywheel - $100
  • Standard Clutch Plate and Clutch Cover (still has about 15000-20000kms left in it) - $200 SOLD
  • Standard Fuel Pump - $130
  • Standard AFM - $120
  • Standard Cat - $50
  • Power FC Commander - $350 (Brand New) SOLD
Located in Wollongong but work in Sydney.
Cheers.
Edited by MR R34
https://www.sau.com.au/forums/topic/197544-fs-r34-parts-cheap/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
