haha you need abit of humour when your day is going like shit...
anyway im guessing the z32 afm is shagged aswell, is there any resistance test or anthing to test the actual afm?
so another update:
I have a spare q45 afm, which i thought i would try. I hooked it up and the afm volts started to read as they should around the .2-.4volts when the engine was off but in the igntion postion. It was around 1v at idle, although it ran very rough (i had it on the vh41 setting for airflow)
I then stuck the stock r33 airflow meter and took it for a drive. The volt reading was simular to the q45, and the car reved as it should and there was no spultering or anything like that throughout the rev range. But it hunts at idle now... 700-1400rpm just goes up down up down.
So i now am concerned about 2 things,
1. why is it hunting?
2. why didnt it like my q45 afm even though i had it on the right afm setting?
I'll try and get some pics of it, the owner has done a decent job at making it look good, now it just needs to go properly haha
thanks again
Edited by R34GTFOUR
as for the hunting side of things, i have reset the powerfc and gave it 30mins to "relearn" its idle, but it didnt work
I kinda knew it wont stop hunting the second i started it up with the reset ecu, it hunted straight away. When we first put a powerfc in my bros car, it never hunted at idle, it just ran really rich until it learnt the idle then it was all good.
BUT... (and there is always a but haha)
if i took timing out from the powerfc (about7-8degrees so its at about 8degrees BTC) then it stops hunting and idles at 950 but its not a normal idle. It kinda sounds liek its struggling even though the rpm doesnt change. If i return the timing to 15 BTC it starts hunting again.
so yeah... still thinking...
Edited by R34GTFOUR
check the physical loom connector to the PFC
as you have been messing around with wires and swapping ECUs check the actual plug is connecting properly
most common causes of crap running with the PFC and wierd idle etc is the actual harness isnt connected or is a bit loose
tighten the bolt a little too to make sure its straight and even and a firm snug fit. you should do the self idle learn, once the ECU is stable
it sounds like the stock AFM and q45 AFM you have are both OK its just you have some wierd idle problem - see above
yeah i'll have a closer look at that tomorrow, although the plug looks fine and i always tighten the bolt to secure it all the way (i even press the outside edges of the plug cause the plug doesnt always go in evenly).
The actual harness itself hasnt really been molested too much, 99% of its be untouched. The only thing thats been "tapped" into is the main power (3pinouts), eccs relay was made up, water temp and tacho feeds to the dash, and the starter signal from the igntion barrel, and all these things check out as good.
I'm starting to feel sorry for the owner cause everything that shouldnt go wrong, has. I mean the odds that his q45 tps, z32 afm and a brand new power ALL being broken are almost statistically impossible but they are haha, i was intitially expecting one thing to be wrong lol
Everything besides the stable idle is working fine. The car revs fine, and powers beautifully right to limiter, no surging and spluttering, it just hunts.
Anyway i'm given up for the night, its only got a front pipe as an exhaust so its bloody loud and i dont want to get noise complaints, i'll wake them up first thing in the morning with it haha.
So tomorrow:
-Im taking my bros powerfc (the owners original powerfc is broken) out and putting it back in his skiz to make sure everything still works as it should (even though i just deleted his tune lol)
-I'm going to let the skiz run then record all the sensor signal voltages, then put the powerfc back into the hq ute and compare the signals, hopefully something jumps out at me.
-If not, im going to go pinout to pinout and record each and every value and compare that to the workshop manual and see what it says.
-If still no joy, i will purchase some fuel and some matches and burn the bastard down to the ground....
once again thanks, your input has helped me alot :D
PROBLEM SOLVED :/
Okay so there was 4 main areas from stopping the rb25 from running properly:
1.
The powerfc was faulty, it didnt give out a tps voltage, I stuck my bros powerfc in it and it works fine. Hopefully he can get his fixed under warrenty
2.
He wired in the z32 afm plug so i just doubled checked the wiring. He was using a diagram that listed the wiring code as 1,2,3,4,5 (5wire plug), going from left to right, but the actual plug has the numbers 1-5 but 1 starts on the far right hand side. What this means is that he wired the signal and voltage back to front (SATO GTS, you were spot on haha). I re-wired it and it works fine now :D
3.
The tps that he had on the q45 wasnt actually a tps, but a throttle switch. The switch was either on or off, there was no variable to it. I stuck my q45 tps, which was the proper tps and problem solved.
4.
Now this last problem got me stumped for a while, and this is what was causing the hunting at idle. On the q45 throttle body it has its own idle up. It uses a coolant line going though it to warm up this valve, and once it hits operating temperature it pushes the throttle back to fully closed. Since we arent running any coolant to it, the throttle was open too much at idle so it was getting to much air and confusing the ecu making it hunt.
I pulled the whole assembly off the throttle body and adjusted the idle screw and it now sits dead on 800rpm, no hunting.
So after a LONG weekend, a car that barely started and hardly ran now starts first go, idles smoothly, and if the diff ratio wasnt so tall would be pretty quick, but it still revs freely and cleanly. Its going to get tuned and the boost upto 12psi and it should go alright for a hq ute.
Thanks again for everyone that replied, especially paul, it helped me alot.
Cheers :(
Edited by R34GTFOUR
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
