Selling the top of the range Nismo GT LSD 2 Way Mechanical Diff, 4.3 Ratio complete in R200 S13/R32 housing with ABS sensor and loom in the nose! These are extremely rare perfect for those wishing to retain their ABS when they upgrade their diff to mechanical, most mechanical diffs are in the non-abs housings which are a little shorter and wont suit ABS vehicles without changing complete tailshaft as the tailshaft is shorter on a ABS model. This is one of the best diffs for a street/track combo being perfectly streetable similar in performance to a ATS Carbon. This diff comes complete with the front diff bolts from S13/R32 to make it a straight fit into S14/R33 applications by just swapping the rear plate (takes 2mins can even do for you if you bring your diff). Comes complete with the 5 bolt half shafts but these can be swapped quite easily with your current diffs six bolt ones they are just held in by circlip so just pull and tap. This one of the best diff centres on the market and the 4.3 ratio will give you a instant increase in acceleration!
Condition - Mint
Price - $850
Location - Adelaide
Contact - PM or sms 0404998591
Edited by nigelswazi
can this be fitted to a non abs r33?
Not without changing the tailshaft
I do have a Nismo 2way in housing for a non-abs R33 that I was going to put in my own car, but need cash to fix a few things up with my car first, if you are interested pm me as may sell
would it fit on a R34 GTT?
Not sure as I have never owned a R34 as long as they still used the R200 diffs then it should.
Price Drop for this weekend only $800
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
