  • Replies 110
It feels like a clutch pedal :blink:
Good news. The box is fixed and it wasn't something massive. The circlip and spring came off the end of the shaft and planted themselves elsewhere in the gearbox. The shaft now has a new circlip and a deeper groove machined to sit in to ensure it's not going to wander out again.
I want to say thanks to PAR for all their assistance and quick turnaround in resolving the issue ;)
It may arrive in time to be installed for the weekend, otherwise it should be back on the road early next week.
lol, I won't be there, at least not driving. Had my third drive tonight, it's going to take a very long time for me to perfect driving manual let alone driving it hard. Excuse the fact I've had my license 7 years, I'm pretty much learning to drive all over again.
183.3fwkw. Not quite as much as I was expecting but we think a few things are restricting it a little (intake and exhaust), boost drops off to wastegate boost pretty early on. O2 sensor hasn't been sorted yet so it's been tuned without one again until that's sorted. The entire loom section for the O2 sensor has been re-wired so it'll at least work once we get it in. Also split a CV boot on the dyno, messy!
If anyone is interested in reading a little bit of my story I did an interview with car blog Obsessive Compulsive Tuning Cars:
Part 1:
http://obsessivecompulsivetuningcars.com/2...ve-for-her-car/
Part 2 to follow.
  • 3 weeks later...
Wow .. I learn't on manual, have only owned manual cars - I don't think I've driven an automatic more than maybe 30 minutes in my driving life. I've taught people to drive manual, but I honestly can't even imagine trying to learn to drive manual after mostly only ever having driven auto... good luck with it :) I think it will only improve your understanding of cars and handling - which I think is what you want to do :)
You're imagining right, it's hard. Especially since the car hasn't been running since the tune and I've got no manual cars to learn it at the moment. It's a very frustrating thing, because I can drive well in an automatic, I can drive fast and have done a fair bit of track work in an automatic and I'd say I was reasonably good at is, but this is like trying to learn to drive all over again after 8 years of having my license. I'll get there eventually but it's going to take me a long time.
Oh...and even with heavy duty clutches its not too different.
I had been on my manual license my about a year when I got the Ceffy with a heavy duty clutch, I stalled 3 times on the day I got it, and once after that reversing up my gravel driveway and that was it...When I jump in mates' cars with heavy clutches I struggle a bit, because the point of engagement is almost always different, as is stiffness, but again, bit of practice and you're all good.
  • 3 weeks later...
Woohoo, I has the Pulsar back. The problems:
  • Throttle was adjusted completely shut. No idea who on earth did that. This was the cause of the car trying to stall/stalling while backing off throttle and the cause of the rough idle.
  • Tune was using the wrong base image file - from an N14. This was causing the overfueling. It now makes 13fwkw more on the same boost - 196.2fwkw, shitloads more torque (617nm according to the dyno lol), the turbo spools much earlier and it makes much more power through the midrange. The hesitation at 4,500rpm is gone. It's quite insane to drive.
  • Hot start enrichment had too much fuel. This was the cause of the car stalling every time it was started warm.
This tune was on 16PSI, previous tune on 17PSI. More power with less boost :(
This will go in down the track when I have an O2 sensor (daughterboard with O2 sensor tune):
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
