Nissan Skyline R34 1999 GT-T
* Yellow
*200kw @ the rear
* Body Kit
* G-Max Rims with new 275/35/R18 on the rear, 235/40/R18 on the front
* New Brakes,
* Hybrid Intercooler, 12psi
* 3.5" Dump pipe from the Turbo back into a 5" cannon (nice note)
* DVD Player,
* 2 x 8" Sunvisour Screens,
* 6" Alpine Splits,
* 12" Alpine type R sub in box,
* 4ch Alpine V12 Amp,
* 5% Tint (DARK)
* New 100,00 km service and service every 5,000k after that.
* Personal Plates
* Custom doors and dash (Yellow)
* Gready Turbo Timer
* Window Lift kit
* Alarm system
Asking Price: $25,000 (Its on car sales for $27,000)
Edited by Hotr34
https://www.sau.com.au/forums/topic/202592-sold/
Good Luck with it Lynden :D Its a beautiful car, I dont think you will be waitin long
Thanks... I will be asking around about yours too k
Edited by Hotr34
https://www.sau.com.au/forums/topic/202592-sold/#findComment-3601395
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
