Make: Nissan
Model: Stagea RS4 2000 model
Milage: 92,000
Transmission: Tiptronic Auto
Colour: Pearl White
Complied? Yes
Currently registered? Yes November 2008
Price: $15,000
Contact: 0411 268 069 or [email protected] (messenger or email)
Comments / Modifications:
This vehicle is standard, and has never been modified (nor are there any signs of modification from the previous owner in Japan).
There are a couple of minor bumper scrapes as shown in the pictures + drivers side mirror.
Standard Features
2.5l Neo 6 cylinder Turbo (206kW, 362Nm)
4 speed Tiptronic Auto 4WD
Auto Climate Control / TV (TV is NTSC, so wont work here)
Power Steering
Power Windows
ABS
Dual Airbags
Factory 16" alloys
Genuine Nissan “Stagea” Floor mats
Cargo blind & net
Xenon Headlights
Genuine Slimline weather shields
Full Dayz Bodykit
The extra’s on the car I added are;
- Autowatch 446Rli Car Alarm with 3-point immobiliser (without turbo timer)
- AC Delco Heavy Duty maintenance free battery
- FM band expander
Reason for sale: I originally purchased the car as I was a Mobile DJ and needed a wagon to lug around my gear so I had this imported, however now that I have permanent nightclub work I don’t need to take anything except my records. It is a beautiful and smooth vehicle to drive (any stagea owner can vouch for that), and I know I will regret selling this, but I have decided to purchase something smaller.
This vehicle has been well looked after and has had regular oil & filter changes. For any additional info please contact me via mobile, pm or messenger
Images:
Edited by Yunis
https://www.sau.com.au/forums/topic/202658-2000-nissan-stagea-rs4/
  • 1 month later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
