Don't miss out on this top diff! Selling a R200 Nismo GT 2 Way Mechanical LSD diff complete in housing to suit S13's, R32's, Cefiro's etc! Complete with 4.1 Ratio and five bolt shafts (shafts are only a circlip fitting easy to swap with your 6 bolt shafts two minute job)! These are one of the best LSD centres around perfect for the street or track. All ready to bolt straight in comes with oil. Get out there and spin two wheels today!
Price - $850 This week just $750
Contact - PM or SMS 0404998591
Location - Adelaide but will ship at your expense around $75 with busfreight more for courier
Pics
Edited by nigelswazi
  • 4 weeks later...
is it possible to get just the center not the hole diff housing? i have a new viscous abs housing i just want a mechanical lsd in it but its hard to find an abs model diff with mech center in it..
thanks
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
