Item: Blitz R-FIT URAS D1 EDITION
Age: New
Condition:
Price: $350
To Fit: (What car) All cars
Contact:
Comments: Adjustable AF control!!!
Blitz R-FIT URAS D1 EDITION. Brand new unit.. $350
What it does : It's a piggy back type system which tricks the airflow meter to change your air flow valuves which result in a "programmable ecu" by tricking the systems airflow. Great for street cars and DIY tuning. Also displays boost,injecotr pulse,water temp, speed, and so forth. It is a "mini gauge".
used 60mm Pivot Water Temp Gauge with sendor and sensor. blue face $80
new RB No name Adjustable Cam gears (Red) $120
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
