1 owner,WR250f 2005 model ,selling due to injury, unit is immaculate and as new.One Industries graphics kit, Pro-Taper handle bars, new maxxis rear tyre, rego papers and all road accessories.Has been used for very minimal local trail riding history, senior owner.
$7200 ono
ph: 0423697701
http://www.bikepoint.com.au/DesktopDefault...ias=bikepointau
https://www.sau.com.au/forums/topic/203988-yamaha-wr250f/
  • 3 weeks later...
  • 1 month later...
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
