R33 WANTED IN QLD
must be: black ,or red not mooroooon or burgendy red, manual, around 100k on the clock, no less than 200rwkw, body in good nick and r.w.c
the you know wat says definitely NO MORE THAN 15g's I'm lucky enough to spend that!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
contact [email protected]
Edited by dztroy
https://www.sau.com.au/forums/topic/204307-r33-wanted-qld/
r33 wanted in qld prefer
must be: black, manual, around 100k on the clock, no less than 200rwkw, body in good nick and r.w.c
dont really care for flash wheels or body kits.
cant spend anymore than 15g's
amasingly enough carsales has some..
Black R33 - 170rwkw - $10K
stockish R33 - $12K - can make 200rwkw with the $3K you save.
190rwkw - $14K - 145,000kms
Why you would want a black car in level 6 water restrictions I have no idea, but there you go.
https://www.sau.com.au/forums/topic/204307-r33-wanted-qld/#findComment-3621770
The 1st one (Black one for $10k) is mine. Its going into the panel shop this week to get all the little scrapes etc fixed, and GTR style front grill fitted so should be mint next week. Will be adjusting the price to $10500.
If you really need 200kw I have a Series 2 GCG high flow garret Turbo, 3.5" front pipe and dump pipe to full Apexi 3" Exhaust, new front mount intercooler, and Mines Computer that I can fit. That should put it at 200rwkw+
$13000 with all that stuff fitted, and dynotuned
The car already has Coilovers, HKS Boost controller, etc so will be a good package
https://www.sau.com.au/forums/topic/204307-r33-wanted-qld/#findComment-3629093
Hi mate,
Have a look at mine for sale at the moment. Just transfered the NSW rego to QLD (12 months). Im on the gold coast if you want to have a look. Id be more than happy to meet you.
link below,
http://www.skylinesaustralia.com/forums/R3...ck-t176581.html
Shoot me a PM or give me a call if interested.
https://www.sau.com.au/forums/topic/204307-r33-wanted-qld/#findComment-3629519
1st of all, thanks everyone for your swift and knowlagable replies...
reidles your car is hot i like it a lot , but i like a lot of 20k r33's out there but just cant afford them sorry,
and xj40 yours is in my radar, is the a/c ice cold? and hows the interior? anything else i should know about the car? and yeah 13k sounds aight with the extra mods.
dztroy
https://www.sau.com.au/forums/topic/204307-r33-wanted-qld/#findComment-3630748
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
