Make:nissan
Model:skyline
Kilometers: just ticked over 100,000
Transmission: manual
Colour: silver
Complied?yes
RWC supplied?n/a
Currently registered?yes
Price: $15,500 or swap + cash my way
Contact:
Comments / Modifications: extreme clutch,fmic,apexi pod, walbro f/p ,full 3in exh and a few other bits n pieces, had 155rwk with just 3in cat back back in jan 07, i guestimate around 170odd rwk now with fmic front pipe /cat added (still on stock boost )
Images: heres a couple old ones (looks the same) * edit more pics further down the page*
Edited by toffy
https://www.sau.com.au/forums/topic/205408-r33-s2-4-door-5spd-155k/
yeah i spotted yours, nice car! , imo they feel better to drive than the 2doors and theyre 5 seat instead of 4 :laugh: . anyways , did the 100k service last week and found out it had already been done in japan including w/p etc :P
  • 1 month later...
Nice car toffy, If i needed another four door in my collection i'd be to glad to help out. i'll send the details to a friend of mine and see if he's interested.
Edited by Traditimeour
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
