Hey guys, heres some stuff to help clear your defects!
Item: Standard R33 turbo airbox
Condition: great!
Price: $40 for the week with a standard snorkel for SMIC or a custom one for FMIC
To Fit: (What car) r33 Skylines
Contact: 0419110110
Comments:I bought this because I thought it would fit because my car was originally a non turbo converted,turns out it didn't so now I have a spare to rent
Item: Standard R33 non turbo airbox modified to suit cars that have been converted
Condition: good!
Contact: 0419110110
Comments: Was the original one that came with the car that I had to modify to fit the turbo setup
I did use the one that was modified for a FMIC to get a RWC and it was fine
Regards,
Adam
https://www.sau.com.au/forums/topic/205433-airboxes-and-snorkels-for-rent/
nar, I am not really wanting to make a business out of this, not yet at least, more so just to help others out. ur right in the sense that I should mention that interstate is probably not really an option.
Adam
Post this in your state section then.
And if you're "trying to help others out", stop trying to make money off them like a petty, small time businessman, and lend it to them for free.
Locked.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
