ive chromed shit loads of engine bay parts for my car and customers cars
you wanna do all 4 covers or just the cam covers?
you wouldnt have some pictures of engine bay covers blinged up would u?
i actullay wanna do the whole rocket+cam covers myself
https://www.sau.com.au/forums/topic/206391-chroming/#findComment-3651622
Yourself??????? if your thinking of using spray cans it looks like crap. Iv been searching for a long time now and all places in Adelaide have said i need to use heat proof(3 layer chroming) or it will change the look of the chrome and turn to a light blue/purple. Im looking at going over most of my engine bay nuts,brackets,rocker covers,alternator cover and so on.
Iv seen a pic of the 2GU UP engine bay and looks unreal but its not heat proof chroming?
https://www.sau.com.au/forums/topic/206391-chroming/#findComment-3651650
oh no defiently not myself, wen it comes to anything close to the engine bay i leave it tothe experts Lol
https://www.sau.com.au/forums/topic/206391-chroming/#findComment-3651653
I have painted my coilpack cover and front dust cover anodised blue... i just need my rocler covers chromed...
https://www.sau.com.au/forums/topic/206391-chroming/#findComment-3651777
any places in perth that do this for a resonable price ? i kinda wana do the hole bay, im also thinking of just polishing it and finishing with some clear coating but im not too sure if that will look as bling as i want it too..
https://www.sau.com.au/forums/topic/206391-chroming/#findComment-3652216
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
