  • Replies 54
What's the best time to get there to enter?
Me and a couple of mates are going to have a run tomorrow night
gates open at 5 for competitors, sometimes 4.50pm thel open, then u got through scrutineering and then u will probly wait around for half an hour or so coz racing starts at 6pm
yep - rev limit clutch dump works well :cool:
nah - something around 4000rpm works from what ive read, then bleed the clutch out or pop it out if you got a hd clutch
otherwise just work around that value - try 4000rpm one time, then 4500 rpm then 3500 rpm, then just feel around them till you find something that works for you
lately ive seen a few gtrs down at the strip runnin like 14s alot off ppl are revvin to like 3000 3500 droppin the clutch and its just bogging off the line, depends really if u gotta heavy duty clutch or not, if not i wouldnt try launching too hard, if u do i think ya should git it 4000rpm+ and practise gettin off the line without bogging it
4000rpm should be alright, i notice some people rev it o 4000rpm and straight out drop the clutch and it bogs, if u go a bit slower on the clutch to keep the revs up and give it plenty of throttle it should launch ok, i have got a 2.0sec 60ft last week in my gtst
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
