hi all dont know if im in the right area but can anyone please tell me if you can get clear tail lights for a 4 door r33...if so where can i get these a i just bought and the ass end looks crap....any help want be truly greatful thanks...
nischic
Edited by nischic
https://www.sau.com.au/forums/topic/207280-97-r33-4-door-tail-lights/
Welcome to Skylines Australia!! Try eBay, they might have some. Altho, saying that, i dont think you should get them. The clear lights look shit on a skyline, but its up to you. Modify your car how you want to, not how other ppl want u to.
4 door, true. I had a look around for you, but can't find anything. How about converting to 2 door tail lights? Its not a direct bolt on swap, but can be done? Or modify clear 2 door lights to fit in with your 4 door? Other than that, I have no idea
I dunno, I kinda like them, in a wierd kinda way. But then again we are all different. We modify our cars for ourselves, not each other. Good luck with that, it'll deffinately be one of a kinda with custom tail lights. Or if you are really adventurous, maybe something different altogether? Ferrari lights moulded into the back? Now thats a cool idea...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
