Hey guys,
Got some bits left over that I need to get rid of.
JUN RB26 Crank Collar $Sold
Apexi Intake kit RB26 $150
VOLK/ RAYS Carbon centre caps. NEW Sold
Rays GT-AV 17x9 +20. Perfect cond, no scratches. Come with tyres. $Sold
HKS 264 step 1 Exhaust Cam RB26 $350
M's Pods with hard pipes RB26 $200
RB26 Std conrods $200 Free pistons (used) $200
RB26 oil pump (used) $50
GTR Fuel Pump $150
TBO R32 Side skirts Black. Need a lil attention $200
All Parts located in Bunbury. Can arrange to deliver to perth for fuel cost.
email [email protected]
or phone 0409117081
Edited by CMS Drifter
https://www.sau.com.au/forums/topic/207413-brand-name-parts-sale/
  • 3 weeks later...
