Have for sale out of Standard R33 GTR-
* Complete GTR head minus rail and injectors (selling sepparately)
includes plenum, throttle bodies, full twin turbo set up,
(rear turbo leaking a little bit, very minor and does not blow smoke)
Cams springs etc all included.
Valves are good, water tested with no leaks, did not blow smoke or miss etc...
$1,800
PRICE DROP $1,680 ====SOLD SOLD SOLD====
* Sump with diff
Good condition no noises
Or leaks
$500
PRICE DROP $350
*Injectors 6 of
Good condition no leaks...***SOLD ****
$320
* Engine mounts with block to mount supports
$150
*2 Cranks. 1 perfect has been linished, crack and bend tested
by west end performance (so you know its good) standard size.
the other has scores at no. 1 bearing, has not been tested.
Will warrant spun crank, if its no good will refund less freight expense.
$550 (1st crank)
PRICE DROP $500
$250 (2nd crank)
PRICE DROP $180
dont have pics at this stage will get some soon.
please email me at [email protected] as its the best way to get in contact.
i will sepparate if the price is right or will sell the lot for cheaper
cheers
Edited by luvsit
https://www.sau.com.au/forums/topic/207769-r33-rb26dett-gtr-head-engine-bits/
just grab it now, then u dont have to wait 6 months :)
I wish mate gotta spend that cash on my other car before the GTR havent even got the 30 out of the 31 yet keep it for 6 months and i will buy it off you
Would you seperate the head bits?
If so, how much for just the head and covers?
Shaun.
As per Shaun's, if you're willing to separate the head I'd be interested in the throttle bodies - please let us know
Cheers
Matt
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
