I did bother to read it and just made a commentary about what normally happens on this forum when stalling or atmo bov's are mentioned. I have no opinion one way or the other. Perhaps you'll notice that I wasn't replying to your post, denoted by the quote in my post.
fair enough, i miss interepted what you were trying to say, ma bad.
update* i unblocked the PCV, but i still have this problem, im not sure why its stalling out, it cant be my fuel pump or my bov as it wasnt doing this before.
thanks, issa.
...I can spend the time to explain how it works
Hey dood,
Nature always tries to equalize, from one extreme to another, be it heat or particulates suspended in liquid. So osmosis, or equalization of a concentration through a semi permeable membrane... (tea through a tea bag into hot water, or water through your kidneys, 02 and C02 through aveoli in your lungs) or hot air from one room to another etc.
When the cylinder charge burns, some gas leaks past the piston rings into the crankcase, that's called blow by. Clearly engines work cus the pressure in the cylinder is higher above the piston then below is, so the piston moves down. Having pressure from blow by below the piston, in the crankcase then lowers the pressure differential, decreasing performance and causing issues with blowing out seals, dip stick etc etc.
The factory setup has a pipe from the cam cover to the intake pipe, then when under boost ingests the blow by, creates a little vacuum under the piston, increasing performance slightly.
On the over run, or when you back off the accelerator and the revs are dropping, a small one way valve opens and suck the blow by from the crank case as well. The one way is there, so when on boost, pressurized air doesn't go back into the crank case.
People remove the cam cover to intake pipe connection, as older cars have more blow by, and ingesting and burning these "already burnt oily gases" lowers the quality of the in cylinder combustion. This why you see ppl use filters on the cam covers (V8's) and just bleed that blow by to the atmosphere. This is illegal though, as the blow by is technically combustion gases that haven't gone through the cat.
Aftermarket, people use a container (oil/air separator) full of stainless steel wool, and route the gases through that, and then have a filter on the oil/air separator (which technically isn't legal either)
Keep in mind that in the stock setup, when on the over run, the PCV valve opens and wants to ingest air from the crankcase AND from the stock pipe to the intake pipe. Seeing as there's already vacuum in front of the turbo, and the pipe is "behind" the AFM, the PCV is ingesting air that's ALREADY BEEN METERED by the AFM… so AFR's stay the same, the ECU doesn't get confused. The issue is when people leave pipes open, or what not and the PCV pulls air from effectively a "leak"
Hope this makes sense. Search SAU, been covered many times, with lots of pictures and theory how people setup after market setups. Once you know what's going on, make sure your setup, is setup correctly otherwise you'll be stalling etc.
Rough outline, hope it helps
Michael
Edited by GeeTR
thanks alot GeeTR, your a champion.
i get what you mean now, so its stalling because its sucking in air which isnt accounted for by the air flow meter. isnt this bad because its sucking it in from the top of the head?
or does it need to be pressurised, thats why its in front of the turbo compressor standard.
thanks alot, issa.
edit: so just putting a filter over it wont stop my stalling problems?
Edited by phat_man
thanks alot, issa.
No worrys man :down:
Well Im not really saying what its doing, as Im still not sure how your fab guy has made the pipe, some pictures would help.
Airs not getting sucked into cam cover breathers, as with the engine running, there’s still going to be some blow by.
Dont mean to palm you off, but its insanely simply concept, thats better shown with pictures.
Check this link... http://www.skylinesaustralia.com/forums/Ca...68174.html&
and all doubts should be alleviated. Hell, the issue, this thread was started for might not even be this :rofl::D
No worrys man :laugh:
Airs not getting sucked into cam cover breathers, as with the engine running, there's still going to be some blow by.
and all doubts should be alleviated. Hell, the issue, this thread was started for might not even be this :):)
thanks for that, i had a read, i think i get whats going on.
now someone asked a question which no one answered in that thread and i want to know sort of the same thing.
i had the pcv pipe that used to run into the air intake pipe bunged, now i unblocked it and it sucks air in, should i put* a valve on it so it can't* suck air in, but so it can* blow out? or should i leave it as it is and just put a filter on it, it still idles abit funny but the computer is learning, and sometimes it stalls before the computer can correct itself.
so basically does it have to breath, or does it just have to blow out?
edited*
thanks alot, issa.
Edited by phat_man
best bet is to get the maker of ur inlet to put 2 nipples to attach the stock hoses on.
my mates rexi made a winding noise when we blocked the vaccum like coming from his rocker cover to the inlet.. im pretty sure your having the same issue.
edited*
thanks alot, issa.
edited so it makes sense.
i had the pcv pipe that used to run into the air intake pipe bunged, now i unblocked it and it sucks air in, should i up a valve on it so it can suck air in, but blow out? or should i leave it as it is and just put a filter on it, it still idles abit funny but the computer is learning, and sometimes it stalls before the computer can correct itself.
thanks alot, issa.
The plenum mounted one way is simply a source of vacum on over run. If you dont intend to set it up legally, then just block it off.
All your trying to manage really, is the fumes wafting out of the cam cover breathers. At minimum you need to stick a filter on there, just to stop crap from falling in.
Your best best to prevent oily mist all over your engine bay, is running the pipes from those cam breathers to a oil / air separator, which your well versed on now :wave: and run a pipe from the separator under the car somewhere, left open.
Again, this isn't legal, but allows the motor to breath, doest make your car ingest oily air under boost (when it matters) Iv seen the PCV connected to can, and another one way on the open end as well.
Cheers
Edited by GeeTR
thanks alot for the help mate, i finally got a picture of my engine bay as it is now.
as you can see the pcv pipe on the right is just open, it was bunged but its just flowing freely. whats my best bet;
just put a filter on the end of it?
put a filter and a one way valve so it cant suck but it can blow out?
put a catch can so its just connected to the open pipe, and the other hose on the catch can goes under the car?
or put a catch can with a filter on it so i block the lines from the plenum going to the head, then connect it so it connects to both the knobs on the head?
im lost atm, thanks again for the help. issa.
update.
i blocked the pipes where the red is, and i put a makeshift fliter on where the yellow is, it fixed the idle alot better, but it still sometimes idles lower and stalls when i slow down???
what else could it be. im pretty sure its got to do with that, as it started happening straight after i installed the intake pipe.
Thank you everyone for you help. i have found the problem to my idling issue... well actually my cousins mechanic found it.
it was a seizing throttle body, it was getting caught on all the shit stuck in there, so he gave it a good clean with some carby cleaner and i was on my merry way, its still seizing up a little, its just the last of the grim getting sucked away... i hope anyway. at least its not stalling anymore and idles properly.
thanks alot, everyone esp to GEETR for your help.
cheers, issa.
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
