hey all i decided to put the fully sik monster tacho into my line to make it go faster, jks
but anyway just wondering if anyone know where im putting it is legal or no? i think it should be ok as it dosnt block vision but if anyone knows other plz let me know,
also is anyone here an auto elctricn or can any one wire up a mosnter tacho? ill pay ya :)
https://www.sau.com.au/forums/topic/208586-is-this-legal/
I don't think you can have the wires hanging loose, but otherwise it may be ok :)
They might only get picky and tell you that it will hurt you in an accident, but other than that, I don't think they can say too much.
https://www.sau.com.au/forums/topic/208586-is-this-legal/#findComment-3688702
my mate got a yellow for his monster tacho and when he got the sticker off we asked what the rule was they told us that it has to b mounted below the steering wheel and shift lights are illegal if they are connected. so where u have it should be fine just unplug the shift light and hide the cables so they cant say u just unplugged it if you get pulled over, they are for racing only.
https://www.sau.com.au/forums/topic/208586-is-this-legal/#findComment-3688868
cool bananas cheers mate
https://www.sau.com.au/forums/topic/208586-is-this-legal/#findComment-3689108
looks cool tho hehe. well i have one in mine shift light is easily taken off
as for wiring, try and get a wiring diagram for the ecu and find where the rpm signal is, the rest should be like the wiring for the lights, ign, ground and such
Edited by Flash89
https://www.sau.com.au/forums/topic/208586-is-this-legal/#findComment-3689435
There will be an rpm signal wire at the back of the dash (for the dash tacho), ignition & illumination feed you should be able to get from headunit and/or back of speedo/rpm cluster.
Pinouts can be found here... http://paulr33.skylinesaustralia.com/diagrams.html
https://www.sau.com.au/forums/topic/208586-is-this-legal/#findComment-3690056
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
