Item: RB20DET ENGINE
Age: 40***KS
Condition: GREAT
Price: $900 MOTOR/MANIFOLDS COILS ETC $1600 WITH TURBO/DUMPIPE/MANIFOLDS
To Fit: (What car) R32,R33,VL,KE70
Contact: PM
Comments: MOTOR IS GREAT, TURBO HAS DONE LESS THAN 2KM DOWN ROAD FOR A TRIAL.
IM PUTTING A RB25/30 IN IT AND THE TURBO WILL NOT BE A GOOD SETUP ON IT HENCE WHY IM SELLING IT, NEVER HAD ANY PROBLEMS WITH THE MOTOR NEVER GOT HOT OR LEAKED ANY FLUIDS, BUYER IS WELCOME TO DO ANY TESTS THEY FEEL ON THE ENGINE. WIL COME WITH COILS IGNITOR,ECU,AFM, INJECTORS.
PM FOR MORE INFO,
https://www.sau.com.au/forums/topic/208599-engine-turbo-package/
turbo is practically sold, unless you want to pay more than what they are paying which is 600 turbo has not ben boosted at all only driven to check for leaks no more than 2km down road.
they are a perfect turbo for rb20.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
