JDM 1990 ST185
2.0 GenII 3S-GTE
175,000 k’s
VIC registered Slimline ‘MRFOUR’
The following marked * is what I have to be installed
Exterior:
Super White II Paint Code: 040
Group A Front Bumper
Group A Reinforcement Bar
Spoiler Removed
Ganador Style Mirrors
Tinted Windows
OzCelica Stickers
Lighting:
Clear Indicators
Clear Headlamps with Halo Rings
6000k Xelux Conversion Xenon HID’s*
Polarg 10mm Wedge (Rear License Plate Illumination)
Narva 10mm Blue LED Parkers
Interior:
ST184 Cluster swap
Momo Steering Wheel
Turbo Timer
Defi Control Unit II w/ Defi Gauges:
- Boost*
- Oil Temperature*
- Oil Pressure*
TRD Short Shift Kit
TRD Type 2 Gear knob
Engine Work Specs:
ECU: Wolf 3D V4+*
Arias Oversized Forged Piston
Eagle Conrods
NGK Iridium Spark Plugs
High Flowed CT26*
Brand New Crankshaft
TRD Metal Head gasket
Engine Bay:
Monsta Tuned Manifold*
Blitz 3’ Stainless Steel Nur Spec R Exhaust*
HKS SSQ BOV*
Cusco Catchcan*
Apexi Power Intake Kit*
Oil Cooler Relocation Kit
Audio and Visual:
Eurovox Double DIN DVD player
Shaved Antenna
Stock Speakers
Driveline:
ST205 Gearbox
Solid Aluminum Diff Mount
Suspension & Brakes:
Cusco Lower Arm Brace*
Cusco Front Strut Bar
Whiteline HD Rear Sway Bar*
Whiteline Rear Strut Bar
Calipers painted red
Wheels & Tyres:
17x7 CSA Tuner Platinum’s
Nankang 215/40R
Coming Soon and Future Plans:
FMIC
Battery to Boot conversion
Car in stock form about one week before purchase
When I started to change the panels over
The other side a few days later
Edited by Silly-Karr
https://www.sau.com.au/forums/topic/209357-silly-karrs-mrfour/
Reppin' OzCelica
Left Hand Rear Quarter Spoilerless
Right Hand Rear Quarter Spoilerless
Whiteline Rear Strubar
TRD Shortshift Kit and Gearknob plus Eurovox DVD player system (Found stock in the New Mitsubishi Pajero's and Outlanders)
Hey there guys I stumbled across this site from ns.com and just though I would sign up here to see whats going in the way of Skylines and also to check out the Classifieds and OT coz theres some funny hit out there haha.
Im from ozcelica.com and spend most my time there usually getting help for my money pit, the GT4 :D
Anyhoo thats me.
Cheers
Luke
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
