  • Replies 112
hey guys, just wondering how could i get a hold of the Skyline Australia sticker ? saw it on a skyline the other day, looks pretty neat... PS: anyone know where SIGN FX is located ?? wanna tint my car !
thanks !
don
I just signed up. When do I get my things? I've been meaning 2 join for a month or so, but everytime I look at my account I have $43, or $41, or $0.01... What do I have to do now? It doesnt have a "Stonecutters" joining ritual, does it?
Yeah, part of the membership includes a paddling :P
