  • Replies 60
yea we went down the esplanade rite through to semaphore n stopped for a while then went bak to anzacs.
seen the most horrific crash on anzacs bout 1.30 though. a older hyundau excel was torn in half one side and bent like a banana on the other side. one person was laying on the ground not moving at all, it looked like the ambo's were putting the covers on him.
scary stuff.
but cheers to ppl that came out n it was fun, and sorry to a few ppl if i hurt ur ears through the heysen tunnels lol. screamer ftw
Sounds like a bad accident.
Any other cars involved?
It was so scary, i was in a bit of stock the whole night... Also from someone (NATHAN) fkn going crazy in Maccas drive thru hahahaha.. it was a good night.. but bad that we lost the rest of the cruise tho....
xox kahli xox
p.s
My squiral is in a lot of pain!! poor little guy! His ears hurt nathan!!
Edited by kahli
i gotta get a screamer pipe that things killa!
kahli figured out how to PM yet????
:P
havent actually been bothered to look aye haha...
xox kahli xox
Nathan we arent going jet skiing today sorry...
thats kool.
see the squirell belongs with me.
and it wasnt my fault at macca's blame other ppl too lol
Did you have a good night last night?? another late night lol... squiral has another sex buddy!! you will never get them MUAHAHHAHAHA! :thumbsup:
i dont want ur squirell lol.
hmmm "plans to take both squirells" ahahaha
Note to self- - Do NOT drive the corkscrew while pissed off and well just dont drive the corkscrew lol
no one needs to know khali
haha dude i forgot about that, you just made yourself look bad hahaha now i remember what happened!
Camo (R33PER) and I were late and you had all departed already, but there were a few other sau people there and everybody ended up at the other coles (as mentioned above).
Ahhh i wondered if u were off SAU! Sorry, shouldve introduced myself. So yeah few of us rocked up at bout 9:30 but was nobody else there so we ended up at my work with a few others. Was a very quiet night on the roads, not many people out.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
