WHAT DO I HAVE TO DO TO SELL THESE THINGS!
Items:
SPARCO SPRINT fixed back race seat - BRAND SPANKEN NEW - STILL IN PLASTIC!
R32 GTR Engine Brackets and 1 mount
R33 Std Viscous LSD - 90,000klm
TRS 4 Point Racing Harness - BRAND SPANKEN NEW - STILL IN BOX!
Contact Details:
PM me or Ph. 0409 901 365 - Adam
Price and price conditions:
Seat - $350 REDUCED $300
Harness - $75 REDUCED $60
R32 GTR Brackets - $50 REDUCED $40
R33 LSD - $200 REDUCED $180
Edited by RB26GTST
https://www.sau.com.au/forums/topic/211151-garage-clean-out/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
