Just an eoi atm
got a cage in the ceffy think its a saftey 21 cage just black with red padding had all bolts and plates.
starting to think it will be more hassle than its worth.
what are ppl willing to pay?
https://www.sau.com.au/forums/topic/212438-cage/
for the right money i would prob pull the one out of my car. Still finding out about this second one as its in a mates ceffy
Edited by FROGGAH
https://www.sau.com.au/forums/topic/212438-cage/#findComment-3767860
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
