This friday is 23 YAY!!! heaps good sun all day so night should be good...!!
Ill grab some numbers on Friday, if anyone needs to know where we are heading next or whatever but ill be giving everyone a sheet anyways..!!
Cant wait :/
  • Replies 118
pm sent to black ninja i live right near glenelg and will be going on cruise but adelaide is 20 min anyway lol
Does that mean you'll pick him up at 10.00pm?
If not I can do it. Just let me know. :(
Stag goes back to Everlast on the Sat morning. The cabin noise is a little too much for me :D Might also fit up the Ohlins coilovers while I'm at it :(
Did Justin put a resonator in what time you heading up there ill drop in and say hello
PM replied... Thanks for the warm welcome guys/gals ! Appreciate that ;) can't wait for the cruise.. ;)
Justin did put a reso in, but the noise between 2,000-3,000 is a tad annoying (can't talk to anyone in the car). Cruising and accelerating (mildly hard) it sounds sweet (inside the car that is). I'm also thinking of replacing the resonator with a hi flo muffler instead.
I'm also thinking of fitting the Ohlins coilovers while I'm at his shop, if he doesn't mind me doing that while the car is on the hoist.
I'll give him a call now. ;)
im going to get the ninja and pretty girl if the cruise can slow right down until i get back with him that would be great that way he can come along to an sa thing and he is invited for sat night
Yeah im sure he will let unless there flat strapped, so what time you heading there
Getting there at 9am. Justin will do it there and then. Quick jobbie.
Then I'm going home to fit the coilovers.
Sorry for hijacking this thread ;)
Back on topic, yeah the weather is meant to be clearing up good. :thumbup:
$54 sounds like the price that Regency used to charge for a 2nd inspection prior to July 1st 2007.
If that was your 1st inspection then you they obviously wrote you up on the wrong register or tier group.....their bad, your luck.
Whiplash is clued up with this stuff, enlighten us with your knowledge & wisdom Nick.
$54 bux is around the old price for second inspection when the first inspection was around $74.
then jumped a few times to around $130 first inspection around $70-75 second
and now its going up again along with police quota's to pull over cars, should be fun :woot:
i might drop by as well...
Woot!
This would bemy first cruise since ive joined up to this forum!
Out of curiosity, has the meeting spot been changed?
Hey,
Nothing has been changed for the cruise. If your really not sure if you are going i can send you the map, but i will be handing it out at Hilton Plaza anyway tonight!! AHH crusie tonight lol :)
beware all,
theres a house accross the road which attracts alot of police attention on weekends for totally unrelated car matters.
so dont be silly around there, or anywhere else for that fact. i might pop past if i can be bothered getting off my arse and giving up watching underbelly for an hour >_<
might ride down if the weather holds up.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
