# plate
20 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
So i ordered new plates at the car show today. Last minute decision, opted for RBR034. And then driving my car home i f**ked clutch / selector fork, and ended up on the back of a tow truck :D ive had better days
So i ordered new plates at the car show today. Last minute decision, opted for RBR034. And then driving my car home i f**ked clutch / selector fork, and ended up on the back of a tow truck :) ive had better days
Yeh good choice with the R and S series, they are a bit more stealth!!
Sorry to hear about clutch issues!!
i like soft34 that keeps it in the $71 bracket and is deceptive :)
Nah, thats a personalised plate then isn't it?
R and S plates for the $71 fee must be three letters (RRR) and three digits (111) right? Like my plate RRS-250
SOFT-34 will be a personalised plate at a once off fee (not yearly) for about $144?
